Aircraft Wheel Bearings – Timken Taper Bearing 629 Inspection codes
For many years Timken Aerospace have provided the mass majority of the worlds aircraft wheel bearings and for good reason they retain their dominant position in this field. Identifying authentic aircraft wheel bearings (taper roller bearings) should be relatively easy because all approved Timken product undergoes a special level of inspection before it leaves the manufacturing plant. This is denoted by the 629 code which is appended to the bearing reference. Without this the bearing is not deemed flight approved and should not be used. Timken aircraft wheel bearings are also packaged in suitably robust and appropriately marked with anti forgery devices.
Timken aerospace
The specialised inspection process includes visual, X-ray crack detection and other methods which standard commercial taper bearings do not receive. When you consider the violent acceleration and heat generated when an stationary aircraft wheel touches the runway at 120 knots and then the immense amount of heat from this acceleration, spike loading plus the heat from the breaking system, you need to ensure the bearings you are fitting have undergone all the appropriate inspection requirements and are airworthy. The 629 code provides you this assurance.
The 629 code is often preceded with a “20? hence you may see 20629 after the cup (taper outer ring) or cone (inner ring, cage and rollers) reference. The “2? implies the precision level and the “0? is simply a spacer character.
The permutations of cups and cones which make up a taper bearing assembly are many but to ensure you have the correct combination you can view the Commercial Aviation Timken aircraft wheel bearings FAA PMA list here.
source: Timken Company
Century Cement,  Revolvo의 분할 롤러 베어링에 큰 만족감 보여
Century Cement, Revolvo의 분할 롤러 베어링에 큰 만족감 보여(0)
Century Cement는 최근 Row Mill 모터드라이브에 분할 롤러 베어링을 적용하여 성공적인 결과를 거두며 인도 라이푸르에 위치한 공장내, 분할 롤러 베어링의 적용범위를 넓혀가고 있다. 이 회사는 과거에 인덕션 모터에 적용했던 OE 화이트 메탈 베어링이 심지어 펌프 오일 순환 윤활시스템을 갖추었어도 수명이 너무 짧아, 유지보수비용을 절감할 솔루션을 찾지 못한다면 기꺼이 새로운 드라이브 시스템의 구매를 고려했었다. Revolve의 판매
향후 베어링 시장 4대 동향
향후 베어링 시장 4대 동향(0)
지난 몇 년 간 산업 전반의 시장 침체와 함께 글로벌 GDP 지수와 밀접한 관련이 있는 베어링 산업도 급격한 수요 감소를 경험하고 있다. 최근 약간의 회복세를 보이긴 하지만, 2008년 재정위기가 시작되면서, 베어링 매출액과 종류의 감소가 지속되고 있다. 하지만 베어링 산업은 지난 몇 년 간의 침체에서 곧 회복될 것으로 전망되고 있다. Global Industry Analysts, Inc. (GIA)는 2018년에
하드드라이브 디스크 검사용 베어링
하드드라이브 디스크 검사용 베어링(0)
The Barden Corporation UK는 박막 코팅 하드 드라이브 디스크의 완전성을 체크하는 엘립소미터(타원분광기) 검열 장비에 장착하기 위한 수퍼 프리시전 베어링 유닛을 동남아시아 지역에 공급해오고 있다. 저 토오크 및 정확한 실행을 특징으로 하는 이번 최신 맞춤 설계 식 베어링 유닛은 스테인레스 강철링과 볼을 통합시켜, 앵글러 컨택트 한, 박편, 겹줄 베어링으로 구성돼 있는 엘립소미터 장비 맞춤식 이다. 이번
자주찾는 카테고리
