Improved Reliability for Large Gearbox Applications Such as Wind Power Generators
NSK CRB1
NSK Ltd. (NSK; Headquarters: Tokyo, Japan; President and CEO: Norio Otsuka) announced that it has developed a high load capacity cylindrical roller bearing for large gearbox applications that achieves longer life thanks to an increase in load capacity over the conventional product. NSK is targeting global sales of 1 billion yen a year in 2015 by expanding the sale of this product for large gearbox applications such as wind power generators, which require high load capacity.
Development Background
The gearboxes* for large industrial machinery such as wind power generators and mining machinery typically use cylindrical roller bearings in order to sustain the high load conditions of such applications. In recent years, wind power generators have increased in size in order to increase generation output. Also, mining machinery is used 24 hours a day, 365 days a year under severe conditions due to the advancements being made in emerging nations. For these reasons, bearings used in such large gearboxes require even higher levels of reliability.
In response to this need, NSK has developed a cylindrical roller bearing with increased load capacity for higher reliability in large gearbox applications.
* Gearbox: A device that converts input revolutions to the desired level of output revolutions through the meshing of multiple gears between the input and output shafts.
NSK CRB2
Product features
1. Longer life by increasing the number of rollers
By increasing the number of rollers, NSK has reduced value of surface pressure exerted on the contact area between the rollers and rings, thereby increasing the load capacity and lengthening the life of the bearing.
2. Optimization of the cage shape for reduced stress
Increasing the number of rollers results in thinner cage walls, which in turn, weakens the cage. NSK countered this side effect by optimizing the cage shape to suppress stress concentration in the cage bar members, thereby achieving a sufficiently strong cage.
NSK CRB3
Product benefits
This product achieves an approximate 30% increase in life over that of the current product, improving the reliability of gearboxes even in harsh environments.
source: NSK
세계 최대 정격하중 스피리컬 롤러 베어링
세계 최대 정격하중 스피리컬 롤러 베어링(0)
스피리컬 롤러 베어링은 레이디얼 하중을 지지하는 베어링산업의 워크호스다. 레이스웨이에 잘 들어맞게끔 두 가닥의 베럴 모양의 롤러로 구성돼 있으며, 이러한 완벽한 매치와 크기, 롤러의 개수 등이 스피리컬 롤러 베어링의 하중 능력을 높여준다. 스피리컬 롤러 베어링은 기본적으로 두 가지 타입이다. 대칭형 롤러 설계방식은 부동식 센터 가이드 플랜지를 사용하여 상대적으로 긴 롤러들이 사용될 수 있으며, 베어링의 레이디얼 하중
ZKL의 신 동력 “밀봉 스피리컬 롤러 베어링”
ZKL의 신 동력 “밀봉 스피리컬 롤러 베어링”(0)
ZKL은 최근 밀봉 스피리컬 롤러 베어링 개발에 성공했다. 올해 그 범위가 확장되며, 고객들은 ZLK의 제품 카탈로그에서 이 신상품을 만나 볼 수 있다. ZKL의 밀봉 스피리컬 롤러 베어링은 올해 5월 출시 예정이다. 밀봉 스피리컬 롤러 베어링’의 이점 이 신제품은 모든 엔지니어링 분야에 응용이 가능하다. 다양한 구조의 부품들의 결합체로써 틸팅과 높은 하중능력을 특징으로 하며, 실행능력이 정확하다. 또한,
Cater Manufacturing,  Silverthin의 100% 미국산 씬 베어링 판매
Cater Manufacturing, Silverthin의 100% 미국산 씬 베어링 판매(0)
여러 분야의 산업현장에서 발생하는 베어링 문제에 대한 해결책을 다년간 제시해온 Carter Manufacturing은 사용자 맞춤식 또는 고객의 엔지니어링 문제해결에 초점을 맞추고 있다. 특히 베어링 제조 전문과들과 견고한 파트너쉽을 구축해 온 가운데, Silverthin Precision Thin Section Bearings은 이들 파트너 중 하나다. 채굴에서부터 조립까지 모든 제조과정이 미국현지에서 이뤄지는 100% 미국산 제품을 생산하는 Silverthin Precision Thin Section Bearings은 이런
