SKF signs SEK one billion supply agreement for new NautilusTM bearing for the wind industry
SKF has signed a three-year supply agreement, worth around SEK one billion for the new generation SKF Nautilus bearing, with a major wind turbine manufacturer. The new multi-megawatt turbine that will utilize the new bearing is intended for both onshore and offshore installations around the world.
Nautilus-Bearing-Solutions
“We are very pleased that our close development cooperation with this leading manufacturer has resulted in this major order. Wind is a relatively new source of energy and it has developed into a significant business for SKF over the past few years. We are in active cooperation with leading companies within the market to develop future technology and this order is proof that our new Nautilus bearing is well accepted in the industry,” says Tom Johnstone, SKF President and CEO.
The new generation SKF Nautilus bearing was launched in April 2012 at the European Wind Energy Conference in Denmark, and is included in the SKF BeyondZero portfolio of customer solutions, which offer significant environmental benefits. Through reduced friction and improved running conditions, the SKF Nautilus bearing contributes to the reduced cost of energy, helping to make wind energy a cost-effective and affordable energy alternative.
Rebecca Janzon, Global Press Manager,
tel: +46 31-337 3880, mobile: +46 727-173880, e-mail: rebecca.janzon@skf.com
Marita Björk, Head of Investor Relations
tel: +46 31-337 1994, mobile: +46 705-181994, e-mail: marita.bjork@skf.com
SKF is a leading global supplier of bearings, seals, mechatronics, lubrication systems, and services which include technical support, maintenance and reliability services, engineering consulting and training. SKF is represented in more than 130 countries and has 15,000 distributor locations worldwide. Annual sales in 2011 were SEK 66,216 million and the number of employees was 46,039. www.skf.com
source: SKF
세계 최대 정격하중 스피리컬 롤러 베어링
세계 최대 정격하중 스피리컬 롤러 베어링(0)
스피리컬 롤러 베어링은 레이디얼 하중을 지지하는 베어링산업의 워크호스다. 레이스웨이에 잘 들어맞게끔 두 가닥의 베럴 모양의 롤러로 구성돼 있으며, 이러한 완벽한 매치와 크기, 롤러의 개수 등이 스피리컬 롤러 베어링의 하중 능력을 높여준다. 스피리컬 롤러 베어링은 기본적으로 두 가지 타입이다. 대칭형 롤러 설계방식은 부동식 센터 가이드 플랜지를 사용하여 상대적으로 긴 롤러들이 사용될 수 있으며, 베어링의 레이디얼 하중
ZKL의 신 동력 “밀봉 스피리컬 롤러 베어링”
ZKL의 신 동력 “밀봉 스피리컬 롤러 베어링”(0)
ZKL은 최근 밀봉 스피리컬 롤러 베어링 개발에 성공했다. 올해 그 범위가 확장되며, 고객들은 ZLK의 제품 카탈로그에서 이 신상품을 만나 볼 수 있다. ZKL의 밀봉 스피리컬 롤러 베어링은 올해 5월 출시 예정이다. 밀봉 스피리컬 롤러 베어링’의 이점 이 신제품은 모든 엔지니어링 분야에 응용이 가능하다. 다양한 구조의 부품들의 결합체로써 틸팅과 높은 하중능력을 특징으로 하며, 실행능력이 정확하다. 또한,
Cater Manufacturing,  Silverthin의 100% 미국산 씬 베어링 판매
Cater Manufacturing, Silverthin의 100% 미국산 씬 베어링 판매(0)
여러 분야의 산업현장에서 발생하는 베어링 문제에 대한 해결책을 다년간 제시해온 Carter Manufacturing은 사용자 맞춤식 또는 고객의 엔지니어링 문제해결에 초점을 맞추고 있다. 특히 베어링 제조 전문과들과 견고한 파트너쉽을 구축해 온 가운데, Silverthin Precision Thin Section Bearings은 이들 파트너 중 하나다. 채굴에서부터 조립까지 모든 제조과정이 미국현지에서 이뤄지는 100% 미국산 제품을 생산하는 Silverthin Precision Thin Section Bearings은 이런
