SKF Solid Oil Bearings Keep the Dough flowing in the Bakery Industry
SKF solid bearing
Solid Oil bearings from global rotating equipment and technology specialists, SKF, provides the ideal solution for the food and beverage industry where conventional lubrication methods of grease and lubrication and ingress of contaminants are simply not options.
A bakery in Germiston, Gauteng, was experiencing continuous unplanned stoppages and downtime on their dough rollers because the bearings were contaminated by the dough which entered the bearings in the rollers. “This ultimately affected production adversely due to unfortunate bearing failure and subsequent line stoppages,” explains Patricia van der Hulst – Key Accounts Manager – Food and Beverage, SKF South Africa (Pty) Ltd, adding that these unscheduled breakdowns were extremely costly.
Some concerns raised by the customer included the fact that because the dough going through the process would stand whilst the repairs were being performed, it had to be discarded. Other factors which added to costs were associated expenses and repairs needed due to failures, loss of production hours and increased stock holding.
The bakery needed an urgent solution and SKF, through distribution partner, Citi Bearings Wadeville, came to the rescue with SKF Solid Oil Bearings – 6307-2RS1/W64F & 6005-2RSH/W64. After installation, the customer reported Mean Time Between Repair (MTBR) increased from 0.5 months to 12.5 months as a result of the new solution. Zero breakdowns were recorded in between.
According to Van der Hulst, Solid Oil bearings have been developed especially for applications where the conventional lubrication methods of grease and lubrication cannot be used. “The bearing is filled with a polymer matrix saturated with lubrication oil that completely fills the internal space and encapsulates the cage and rolling elements.”
The solution is ideal in situations where the bearing is in a difficult-to-reach or dangerous location, and is excellent when contaminant exclusion is required. van der Hulst points out that the Solid Oil bearings are available in a food grade, as well as a non-food grade option and most bearings can be filled with solid oil.
Van der Hulst says the customer reports numerous benefits such as increased availability of production machinery as a result of a reduction in unplanned downtime. In addition, the improvement in machine reliability has reduced the number of associated expenses and repairs needed on auxiliary equipment and components such as couplings, gears, shafts, housings, bearings, seals, electric motors, etc. Free re-lubrication saves on lubricant costs. And finally, the increased service life, due to fewer failures, results in less unplanned machine downtime, and consequent loss of production hours as well as less waste of dough. In conclusion, Van der Hulst points out that the customer value and relationship is of utmost importance to SKF. “We understand that downtime is simply not an option for our customers and, together with our distributors, we remain committed to providing fast, effective and cost saving solutions.”
source: SKF
Century Cement,  Revolvo의 분할 롤러 베어링에 큰 만족감 보여
Century Cement, Revolvo의 분할 롤러 베어링에 큰 만족감 보여(0)
Century Cement는 최근 Row Mill 모터드라이브에 분할 롤러 베어링을 적용하여 성공적인 결과를 거두며 인도 라이푸르에 위치한 공장내, 분할 롤러 베어링의 적용범위를 넓혀가고 있다. 이 회사는 과거에 인덕션 모터에 적용했던 OE 화이트 메탈 베어링이 심지어 펌프 오일 순환 윤활시스템을 갖추었어도 수명이 너무 짧아, 유지보수비용을 절감할 솔루션을 찾지 못한다면 기꺼이 새로운 드라이브 시스템의 구매를 고려했었다. Revolve의 판매
향후 베어링 시장 4대 동향
향후 베어링 시장 4대 동향(0)
지난 몇 년 간 산업 전반의 시장 침체와 함께 글로벌 GDP 지수와 밀접한 관련이 있는 베어링 산업도 급격한 수요 감소를 경험하고 있다. 최근 약간의 회복세를 보이긴 하지만, 2008년 재정위기가 시작되면서, 베어링 매출액과 종류의 감소가 지속되고 있다. 하지만 베어링 산업은 지난 몇 년 간의 침체에서 곧 회복될 것으로 전망되고 있다. Global Industry Analysts, Inc. (GIA)는 2018년에
하드드라이브 디스크 검사용 베어링
하드드라이브 디스크 검사용 베어링(0)
The Barden Corporation UK는 박막 코팅 하드 드라이브 디스크의 완전성을 체크하는 엘립소미터(타원분광기) 검열 장비에 장착하기 위한 수퍼 프리시전 베어링 유닛을 동남아시아 지역에 공급해오고 있다. 저 토오크 및 정확한 실행을 특징으로 하는 이번 최신 맞춤 설계 식 베어링 유닛은 스테인레스 강철링과 볼을 통합시켜, 앵글러 컨택트 한, 박편, 겹줄 베어링으로 구성돼 있는 엘립소미터 장비 맞춤식 이다. 이번
